Site was up and working normally, then after a password reset and entering a new password, I see a 404 page:
Request made from incorrect origin. Expected ‘htp://info.blog.mydomain.com’ received ‘’.
nginx error log shows:
2018/11/20 07:10:11 [error] 31818#31818: *26 connect() failed (111: Connection refused) while connecting to upstream, client: 113.113.203.212, server: info.blog.mydomain.com, request: “GET /favicon.ico HTTP/1.1”, upstream: “htp://127.0.0.1:2368/favicon.ico”, host: “info.blog.mydomain.com”, referrer: “”
nginx access log shows:
113.113.203.212 - - [20/Nov/2018:07:10:10 +0000] “GET /ghost/ HTTP/1.1” 502 584 “” “Mozilla/4.0 (compatible; MSIE 999.1; Unknown)”
ghost log shows:
level: normal
empty
empty
ERROR DETAILS:
empty
BadRequestError: Request made from incorrect origin. Expected ‘htp://info.blog.nopsema.gov.au’ received ‘’.
at new BadRequestError (/var/www/ghost/versions/2.6.0/node_modules/ghost-ignition/lib/errors/index.js:94:23)
at cookieCsrfProtection (/var/www/ghost/versions/2.6.0/core/server/services/auth/session/middleware.js:112:21)
at Layer.handle [as handle_request] (/var/www/ghost/versions/2.6.0/node_modules/express/lib/router/layer.js:95:5)
at next (/var/www/ghost/versions/2.6.0/node_modules/express/lib/router/route.js:137:13)
at /var/www/ghost/versions/2.6.0/node_modules/express-session/index.js:489:7
at Child.SessionModel.findOne.then (/var/www/ghost/versions/2.6.0/core/server/services/auth/session/store.js:26:17)
at Child.tryCatcher (/var/www/ghost/versions/2.6.0/node_modules/bluebird/js/release/util.js:16:23)
at Promise._settlePromiseFromHandler (/var/www/ghost/versions/2.6.0/node_modules/bluebird/js/release/promise.js:512:31)
at Promise._settlePromise (/var/www/ghost/versions/2.6.0/node_modules/bluebird/js/release/promise.js:569:18)
at Promise._settlePromise0 (/var/www/ghost/versions/2.6.0/node_modules/bluebird/js/release/promise.js:614:10)
at Promise._settlePromises (/var/www/ghost/versions/2.6.0/node_modules/bluebird/js/release/promise.js:694:18)
at _drainQueueStep (/var/www/ghost/versions/2.6.0/node_modules/bluebird/js/release/async.js:138:12)
at _drainQueue (/var/www/ghost/versions/2.6.0/node_modules/bluebird/js/release/async.js:131:9)
at Async._drainQueues (/var/www/ghost/versions/2.6.0/node_modules/bluebird/js/release/async.js:147:5)
at Immediate.Async.drainQueues [as _onImmediate] (/var/www/ghost/versions/2.6.0/node_modules/bluebird/js/release/async.js:17:14)
at runCallback (timers.js:810:20)
Looks like nginx is not passing an origin parameter through to ghost. The nginx site conf is:
server {
listen 80;
listen [::]:80;
server_name info.blog.nopsema.gov.au;
root /var/www/ghost/system/nginx-root;
location / {
location ~ /.well-known {
allow all;
client_max_body_size 50m;
Any clues?
