I’d like to be able to integrate our Amazon Storefront into a Ghost post. We have our holiday gift guide all set up on Amazon, but I don’t see a good way to display it programmatically. We do these sorts of list frequently, so making this easy would be a HUGE win. I just don’t even know where to start, frankly. I’d like some guidance if at all possible?
Thanks,
Ron
I usually skip the full storefront embed and pull in the items with Amazon’s Product Advertising API, then drop them into a simple HTML card in Ghost. It keeps things cleaner and loads faster than iframe workarounds. If you want layout ideas or sample snippets, I’ve grabbed inspiration from sites like [moderator: link removed], which mix external sources smoothly without heavy plugins.
