I’m planning on building a Media Platform, with some Client Side (Web & Mobile) Applications.
The backend isn’t supposed to be complex.
It just needs to:
- Provide User Authentication of some sort (JSON Web Tokens or similar)
- Manage Permissions & Protect specific routes from unauthorized users.
- Make it easier to create & manage collections.
- Make it easy to form relations between collections.
I was looking for a headless solution. I came across Strapi, and Ghost. But Ghost also seems to have a front-end despite having a Full API.
I was wondering if it’s possible to disable this & only use the API to Get, Update, Create, & Delete Data.
So is Ghost a good choice for me or should I stick with something like Strapi instead ?
I preferably wanna deploy this in a docker container.
Thank you for any assistance.
