Is it possible to use custom Schema.org data for posts
I’m working on a recipe blog, and I’d like to include recipe metadata adhering to the Schema.org format for recipes - however, I don’t see any way to customize the metadata for blog posts in the interface. Would really appreciate if anyone knew a way to go about this - thanks!
One of the many reasons I use Ghost as a headless CMS and ran with a custom frontend. I’m pretty sure what you want to do is achievable with little modification to your template. Perhaps a jsonld in the post.hbs? I’m only guessing without having a look myself.
Thanks for the reply Sylar, is there a way to define custom attributes in the Ghost post objects? if so, that could work for surfacing them in the post.hbs file
