Hello! I’m translating an article and ready to publish it on Ghost. However, I found that the Tableau visualization embedded in that article has a different width from the text. If I embed the code, the visualization block will be compressed and cannot have a full display. Please note that I want to keep the current text width but to extend the width for the visualization.
In your HTML card, wrap the Tableau embed like this:
<div class="kg-width-wide">
<!-- Put your Tableau code here -->
</div>
This will make the embed a bit wider than the content. (It’s using the same class the theme uses for wide images.) Depending on the embed code, you may need some further adjustments — just let us know how it works.
Yep. When you add a photo to Ghost Editor, there’s an option to change the width to wide (1) and full-bleed (2). It’s up to themes how they implement this, but Bulletin does support it.
