The first time I tried to post with ghost, I had a little problem: the instagram card wasn’t scaling horizontally. So I corrected this by changing the kg-card
css class height and everything worked out fine.
Now I tried to post with a integrated vimeo video and I saw that the post is coming out with the same class: kg-card
and its buggy because of the previous fix done with instagram card.
I could probably make a hacky fix using javascript but I really don’t want to do that.
Is there any way to add the application name, like kg-card instagram
and kg-card vimeo
to the respective card without modifying the source code?
Thank you very much!
Pss: I freaking LOVE ghost <3
