This is probably very amateur hour but none of the forums suggestions work for my out of date certificate.
/etc/letsencrypt/acme.sh --home “/etc/letsencrypt” --renew -d YOUR_DOMAIN.COM → doesn’t work
ghost setup ssl-renew → doesn’t work
banging the keyboard randomly → doesn’t work
I’m running the latest v. of Ghost and node. Very headscratching. Is it just that Let’s Encrypt take time on their end to push a renewed certificate? Any solutions, including the very lateral, much appreciated.
self-hosted and am on the latest Acme SSL client. Had to use sudo and --force with Acme to get Let’s Encrypt to run.
AND
when I look at the certs in the command line, they appear to be renewed and go on till mid-October. It’s only in the browsers (multiple; rebooted) where they say the cert is expired.
Is there a way to manually delete all certs and then recert? I’m whatever the opposite of an expert is but it seems like my newer certs aren’t being read because an older expired cert must be coexisting in the directory (wherever that is).
