/*! sanitize.css v7.0.2 | CC0 License | github.com/csstools/sanitize.css */*,:after,:before{background-repeat:no-repeat;box-sizing:border-box}:after,:before{text-decoration:inherit;vertical-align:inherit}html{font-family:system-ui,-apple-system,Segoe UI,Roboto,Ubuntu,Cantarell,Oxygen,sans-serif,Apple Color Emoji,Segoe UI Emoji,Segoe UI Symbol,Noto Color Emoji;line-height:1.15;-moz-tab-size:4;-o-tab-size:4;tab-size:4;word-break:break-word}body{margin:0}h1{font-size:2em;margin:.67em 0}hr{height:0;overflow:visible}main{display:block}nav ol,nav ul{list-style:none}pre{font-family:Menlo,Consolas,Roboto Mono,Ubuntu Monospace,Oxygen Mono,Liberation Mono,monospace;font-size:1em}a{background-color:transparent}abbr[title]{text-decoration:underline;-webkit-text-decoration:underline dotted;text-decoration:underline dotted}b,strong{font-weight:bolder}code,kbd,samp{font-family:Menlo,Consolas,Roboto Mono,Ubuntu Monospace,Oxygen Mono,Liberation Mono,monospace;font-size:1em}small{font-size:80%}::-moz-selection{background-color:#b3d4fc;color:#000;text-shadow:none}::selection{background-color:#b3d4fc;color:#000;text-shadow:none}audio,canvas,iframe,img,svg,video{vertical-align:middle}audio,video{display:inline-block}audio:not([controls]){display:none;height:0}img{border-style:none}svg{fill:currentColor}svg:not(:root){overflow:hidden}table{border-collapse:collapse}button,input,select,textarea{font-family:inherit;font-size:inherit;line-height:inherit}button,input,select{margin:0}button{overflow:visible;text-transform:none}[type=button],[type=reset],[type=submit],button{-webkit-appearance:button}fieldset{padding:.35em .75em .625em}input{overflow:visible}legend{color:inherit;display:table;max-width:100%;white-space:normal}progress{display:inline-block;vertical-align:baseline}select{text-transform:none}textarea{margin:0;overflow:auto;resize:vertical}[type=checkbox],[type=radio]{padding:0}[type=search]{-webkit-appearance:textfield;outline-offset:-2px}::-webkit-inner-spin-button,::-webkit-outer-spin-button{height:auto}::-webkit-input-placeholder{color:inherit;opacity:.54}::-webkit-search-decoration{-webkit-appearance:none}::-webkit-file-upload-button{-webkit-appearance:button;font:inherit}::-moz-focus-inner{border-style:none;padding:0}:-moz-focusring{outline:1px dotted ButtonText}details,dialog{display:block}dialog{background-color:#fff;border:solid;color:#000;height:-moz-fit-content;height:-webkit-fit-content;height:fit-content;left:0;margin:auto;padding:1em;position:absolute;right:0;width:-moz-fit-content;width:-webkit-fit-content;width:fit-content}dialog:not([open]){display:none}summary{display:list-item}canvas{display:inline-block}template{display:none}[tabindex],a,area,button,input,label,select,summary,textarea{touch-action:manipulation}[hidden]{display:none}[aria-busy=true]{cursor:progress}[aria-controls]{cursor:pointer}[aria-disabled],[disabled]{cursor:disabled}[aria-hidden=false][hidden]:not(:focus){clip:rect(0,0,0,0);display:inherit;position:absolute}:root{--show-fade-animation:1}[data-theme=light]{--background-color:#fff;--primary-foreground-color:#4a4a4a;--secondary-foreground-color:#000;--primary-subtle-color:#0470ee;--secondary-subtle-color:#f4f8fd;--titles-color:#333;--link-color:#133467;--primary-border-color:#9b9b9b;--secondary-border-color:#f0f8ff;--article-shadow-normal:0 10px 10px rgba(0,0,0,.08);--article-shadow-hover:0 4px 60px 0 rgba(0,0,0,.2);--transparent-background-color:hsla(0,0%,100%,.99);--footer-background-color:#133467;--submenu-shadow-color-opacity:0.25;--button-shadow-color-normal:hsla(0,0%,42%,.2);--button-shadow-color-hover:hsla(0,0%,42%,.3);--table-background-color-odd:#fafafa;--table-head-border-bottom:#e2e2e2;--toggle-darkmode-button-display-moon:block;--toggle-darkmode-button-display-sun:none;--toggle-darkmode-background-color:rgba(0,0,0,.05);--header-menu-gradient-first-color:hsla(0,0%,100%,0);--header-menu-gradient-second-color:#fff;--kg-card-img-invert-color:0}[data-theme=dark]{--background-color:#111;--primary-foreground-color:#ccc;--secondary-foreground-color:#fff;--primary-subtle-color:#2c2fe6;--secondary-subtle-color:#141920;--titles-color:#b4b4b4;--link-color:#b6b7f6;--primary-border-color:#1d1d1d;--secondary-border-color:#0f0f0f;--article-shadow-normal:0 4px 5px 5px rgba(0,0,0,.1);--article-shadow-hover:0 4px 5px 10px rgba(0,0,0,.1);--transparent-background-color:rgba(0,0,0,.99);--footer-background-color:#080808;--submenu-shadow-color-opacity:0.55;--button-shadow-color-normal:hsla(0,0%,4%,.5);--button-shadow-color-hover:hsla(0,0%,4%,.5);--table-background-color-odd:#050505;--table-head-border-bottom:#1d1d1d;--toggle-darkmode-button-display-moon:none;--toggle-darkmode-button-display-sun:block;--toggle-darkmode-background-color:rgba(0,0,0,.5);--header-menu-gradient-first-color:hsla(0,0%,7%,0);--header-menu-gradient-second-color:hsla(0,0%,7%,.65);--kg-card-img-invert-color:1}.hide{display:none}.sr-only{clip:rect(0 0 0 0);-webkit-clip-path:inset(100%);clip-path:inset(100%);height:1px;overflow:
This file has been truncated. show original
