Link in Solo Theme Site Description/Headers
Hello,
Hopefully this is an easy fix with code injection, hopefully someone’s already solved it.
I’ve been looking to add an internal HTML link (e.g. to a Page) to a word on either the Primary or Secondary Header/Site Description. I can’t quite figure it out.
If I can get that working (and having tags display next to Time to Read on Homepage display of various posts) I will be a very happy camper.
I can’t figure out how to add to or override the class. I believe it is the following:
> <div class="gh-about-content">
>             <div class="gh-about-content-inner">
>                     <h1 class="gh-about-primary">Welcome to my site</h1>
>                     <p class="gh-about-secondary">Subscribe below to receive my latest posts directly in your inbox</p>
>                         <div class="gh-subscribe-input gh-portal-close" data-portal="">
>                             jamie@example.com
>                             <span class="gh-btn gh-primary-btn">Subscribe</span>
>                         </div>
>             </div>
>         </div>
>                             jamie@example.com
>                         </div>
>             </div>
>                             jamie@example.com
>                         </div>
Thanks,
— G.
Do you want to do this for all people or just non members. In essence, you have to download the solo theme, edit the index.hbs class which will show this part of the code you have posted, change the gh-portal-close part to a link or button whatever you want. Save. Then build a zip. The instructions for building a theme are in every default’s themes github repo GitHub - TryGhost/Solo: A personal theme for Ghost
