Lyra Theme Error
Hi All,
I’ve update ghost to version 3.2 and enabled members and insalled the lyra theme:
I’m getting the following errors or browsing to the url:
[2019-12-26 06:53:36] ERROR
CODE: parameter_invalid_integer
MESSAGE: Invalid integer:
Error: Invalid integer:
at Function.generate (/var/www/ghost/versions/3.2.0/node_modules/stripe/lib/Error.js:49:16)
at IncomingMessage.res.once (/var/www/ghost/versions/3.2.0/node_modules/stripe/lib/StripeResource.js:168:39)
at Object.onceWrapper (events.js:313:30)
at emitNone (events.js:111:20)
at IncomingMessage.emit (events.js:208:7)
at endReadableNT (_stream_readable.js:1064:12)
at _combinedTickCallback (internal/process/next_tick.js:138:11)
at process._tickDomainCallback (internal/process/next_tick.js:218:9)
Any ideas?
