Lyra theme signin/signup
Good evening,
I adjust my post.
I had badly imported the template.
I reinstalled Ghost and re-downloaded the Lyra template from github.
I imported the new router.yaml file, but when I click on signin o signup I get the error 400.
I take the opportunity to notify a wrong link in the documentation.
At the end of this page, the “theme development” link redirect to a 404 page.
Thank you.
Thanks! Just fixed that broken link and it will be live in just a moment :slight_smile:
Once you’ve imported routes.yaml you’ll need to restart Ghost for it to take effect. Let us know how you get on!
Hello!
I tried both to restart and stop it completely and start it.
I encounter error 400.
# 400
Missing template members/signin.hbs for route "/signin/".
[Go to the front page →](http://localhost:2368/)
As you can see I’m testing locally.
In the root, I see the “members” folder and the account/signin/signup.hbs file correctly
I would also like to notify this warning message when I import Lyra just downloaded from github:
## Warnings
####  Replace  `{{#each}}`  with  `{{#foreach}}`
](http://localhost:2368/ghost/)The  `{{#foreach}}`  helper is context-aware and should always be used instead of Handlebars  `{{#each}}`  when working with Ghost themes.
See the description of  `{{#foreach}}`  helper [here](https://ghost.org/docs/api/handlebars-themes/helpers/foreach/).
###### Affected files:
  * `index.hbs` : Please remove or replace undefined from this template
I am also facing same error.
I have moved all the template files ( account.hbs, signin.hbs and singup.hbs ) from the members directory to theme root.
In each file changed {{!< ../default}} to {{!< default}} for the correct path of default.hbs template/
Also changed the routes in routes.yaml as following
routes:
  /signup/: signup
  /signin/: signin
  /account/: account
It’s working. But from the sub-directory members or any other sub-directory no templates are accessible.
Same 400 error with same missing template message.
NOTE: I am testing on local machine, development mode. OS- WIndows 10
Theme development link ( https://ghost.org/docs/members/theme-requirements/) is broken again.
This page has moved to: https://ghost.org/docs/members/pre-requisites/
Same thing here, the members directory is being ignored and so i’m getting 400 Template missing errors.
Testing on a local copy installed via Ghost-Cli on Windows 10
seems to be a local windows problem, on ubuntu I don’t see the problem.
Definitely a windows issue.
Found a workaround, changing the route paths to use back slashes instead of the forward slashes works
like this
routes:
/signup/: members\signup
/signin/: members\signin
/account/: members\account
I confirm, it works, thanks!
