I am self-hosting Ghost, and just installed 4.0.0 using the Ubuntu instructions. In general, it worked flawlessly. However since I cannot turn off the membership feature now, I am trying to hook up Mailgun using the bulk email API (not SMTP). I have another site using Mailgun, so am pretty familiar with it, but when I try and enter the sandbox account and API key into the settings of Ghost, I get the following error in the log when an email goes out:
MESSAGE: Failed to send email. Reason: Greeting never received.
level: normal
“Please see Configuration - Adapt your publication to suit your needs for instructions on configuring email.”
EmailError: Failed to send email. Reason: Greeting never received.
at EmailError.GhostError (/var/www/ghost/versions/4.0.0/node_modules/@tryghost/errors/lib/errors.js:10:26)
at new EmailError (/var/www/ghost/versions/4.0.0/node_modules/@tryghost/errors/lib/errors.js:34:20)
at createMailError (/var/www/ghost/versions/4.0.0/core/server/services/mail/GhostMailer.js:52:12)
at EventEmitter. (/var/www/ghost/versions/4.0.0/core/server/services/mail/GhostMailer.js:119:28)
at Object.onceWrapper (events.js:422:26)
at EventEmitter.emit (events.js:315:20)
at EventEmitter.emit (domain.js:467:12)
at DirectMailer. (/var/www/ghost/versions/4.0.0/node_modules/directmail/lib/mailer.js:185:42)
at SMTPClient. (/var/www/ghost/versions/4.0.0/node_modules/directmail/lib/mailer.js:277:9)
at SMTPClient.emit (events.js:315:20)
at SMTPClient.EventEmitter.emit (domain.js:467:12)
at SMTPClient. (/var/www/ghost/versions/4.0.0/node_modules/simplesmtp/lib/client.js:293:18)
at listOnTimeout (internal/timers.js:554:17)
at processTimers (internal/timers.js:497:7)
In my configuration JSON is the default config that got written out during install, so my mail transport is “Direct”, with no other properties. Am I missing something? How do I turn on “bulk email”?
Thanks in advance.
