List of all postings - shows name, location, but the e-mail address is missing,
Simplest way to add the e-mail address?
The simplest solution would be to put the email address in the bio which can be done from the Staff users profile (Settings → Staff).
Yes this is possible, but a mailto link can not be inserted.
I tried to modify the author.hbs file in this way
{{#if mail}}
{{/if}}
but this not possible - the “internal notification” mail variable isn’t available in this context.
That’s correct, it would have to be a text inclusion in the bio, and it’s not possible to pull in the email associated with the staff user with helpers.
If you have a set number of authors, another thing you could do is create custom author templates for each specific author: Author Context: Ghost Themes - Documentation
That way, you can add the author emails as mailto links directly using HTML in each template file.
