Making post title automatically link to standalone post
I’m creating a classic-style blog theme, where full content of all posts is shown on the homepage, but I’d like visitors to be able to click the title of each post and reach a permalink/standalone version of that post.
In my index.hbs I have the following code which renders the full content of all posts on the homepage:
 {{#foreach posts}}
     {{> content }}
 {{/foreach}}
I know that it’s also possible to create a link to the standalone version of each post using:
{{#foreach posts}}
  {{#link href=(url) class="post-link" activeClass="active"}}
    {{title}}
  {{/link}}
{{/foreach}}
However, the issue is that this then doubles the post title, showing it once as {{title}} and then again through {{content}}, and also causes other formatting issues
What I’d like is a way to alter the {{title}} element that is already outputted as part of {{content}} for each post, so that the title always links to the permalink for that post. Does anyone know the best way to do this? Thank you!
The cool thing about partials is you can use them like Components in common frameworks!
So you could do something like this:
# index
{{ > content titleLink=(url) }}
# partials/content
<h2>
{{#if titleLink}}
  {{#link other_attributes href=titleLink}}{{title}}{{/link}}
{{else}}
  {{title}}
{{/if}}
</h2>
Wow, amazing, I didn’t know this – thank you so much!
Sorry, one more question: in this setup, how do I then generate all the rest of {{content}} minus the title? It still seems to be doubling the title, though I may have messed up something else as well!
Are you able to share a snippet of your content partial?
The {{content}} will only output post content (since it’s actually a wrapper around the content variable), while {{> content}} will render the content partial, which is whatever is in partials/content.hbs
Thanks again, sorry for late replies! Following your advice, my code now looks like this – I’m working on a fork of the standard Edition theme, if that helps at all
index
    <div class="post-feed expanded container medium">
             {{#foreach posts}}
                    {{> content }}
            {{/foreach}}
    </div>
partials/conent
    <h1 class="single-title">
        {{#if titleLink}}
        {{else}}
            {{title}}
        {{/if}}
    </h1>
ok, I’ve got it! for my purposes the best solution was just adding {{#link href=(url)}}{{title}}{{/link}} – thanks so much for leading me here Vikas!
partials/content
    </h1>
