Hello,
I created some tables with Markdown Tables generator - TablesGenerator.com but I can’t get them aligned to the left. I’m using the stock theme. Any guess?
Thanks
Hello,
Thanks
Sounds like you need to add some CSS to align them. do you have a link to an example on your site?
I’m running into the same issue. Its odd because in the editor they do react appropriately to markdown left/center, but something is overriding it on the published page…
