My current installation of ghost is using S3 content adapter and storage. Iām thinking about moving back to local storage. I thought it would be just be configuration change but it appears S3 URL is written inside the code of each post.
Is there a way to simply move back to local storage ?
If I do a database json export, remove all the S3 URL, and import back the data, would it work?
We are talking of a personal blog and simple installation without a lot of users.
After 1 year of usage, I am more aware of how much space I need and I know that local hard disk is enough
I can benefit out of the box from image resizing features
For ethical reason, I would like to get rid of amazon services
Another scenario would be to change the s3 provider (and use a local s3 with minio for example) but I guess I will face the same difficulties. This could happen to bigger customers.
Edit 1 of the files, done a search for cdn.mydomain.com/ and replaced it with mydomain.com/content/images/ and save. You may have to play about with these 2 values depending on how you saved to your s3 bucked.
Back in Ghost Admin, delete all content, and then import content.
