Continuing the discussion from Recommended Method to run multiple Ghost instances?:
If I am using the IP address of the server for one of the ghost blogs what am I to use for the IP address of the other? Is there a way to use a port of the IP?
I do have a domain name for this project, but want to build with the IP address as a temp domain per se.
In the end I want one ghost blog at a subdomain and the other at another sub domain. For example
blog1.mydomain.com
blog2.mydomain.com
Thank you!
