Summary of issue:
I’m trying to update to Ghost v4. I first ran ghost update v3 to try to update to the latest v3 version. Then MySQL database appears to be down right now, but I don’t really know where to look for the problem (I have little experience)
If you aren’t running the latest version of Ghost, the first thing we will ask you to do is update to the latest version of Ghost.
What’s your URL? [completed] (in addition, portfolio is on the same droplet and is also not accessible via web browser, comes up with 502 bad gateway
When I runghost ls, blog is not running and portfolio is running) - What version of Ghost are you using? If it’s not the latest, please update Ghost first before opening your topic. I am stuck on 3.42.3 for my blog
- How was Ghost installed and configured?
I have a multisite setup. The first blog was installed with the Digital Ocean one-click install and the second blog was installed following this site https://imaweb.dev/set-up-multiple-ghost-blogs-on-one-digital-ocean-droplet/ I am trying to update the second blog.
- What Node version, database, OS & browser are you using?
OS: Ubuntu, v18.04.4 LTS
Node Version: v12.18.0
Ghost Version: 3.42.3
Ghost-CLI Version: 1.16.3
Environment: production
Database version I am not sure how to check, as when I run mysql from the folder where ghost is, I have this error
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
I am using Safari for web browser
Errors when I run ghost doctor:
Local MySQL install was not found or is stopped. You can ignore this if you are using a remote MySQL host.
Alternatively you could:
a) install/start MySQL locally
b) run `ghost install --db=sqlite3` to use sqlite
c) run `ghost install local` to get a development install using sqlite3.
? Continue anyway? No
✖ Checking for a MySQL installation
One or more errors occurred.
1) Checking for a MySQL installation
Message: MySQL check failed.
Errors when I run ghost update:
✖ Updating to a major version
An error occurred.
Message: 'connect ECONNREFUSED 127.0.0.1:3306'
If I try to run any commands with mysql, this comes up:
- Install ghost with the digital ocean one-click installation
- have another ghost installation in another folder on the same droplet following this link https://imaweb.dev/set-up-multiple-ghost-blogs-on-one-digital-ocean-droplet/
Both of my sites were up. Then I went to update to Ghost v4 - update npm from 6.14.4 → 7.6.3 using
npm install -g npm - update ghost-cli
- update the second ghost installation from 3.40.5 to 3.42.3 using
ghost update v3 - try to update the second installation to v4 by using
ghost update, but database is down
