Need help with install error
? Do you want to start Ghost? Yes
Running sudo command: systemctl is-active ghost_xingbaifang-com
A ProcessError occurred.
Message: Command failed: /bin/sh -c sudo -S -p ‘#node-sudo-passwd#’ systemctl is-active ghost_l
oclhost
failed
Exit code: 3
OS: Ubuntu, v16.04
Node Version: v6.14.3
Ghost-CLI Version: 1.8.1
Environment: production
Command: ‘ghost install’
I don’t know where is error.
hi can you try
sudo systemctl start ghost_localhost
then
ghost start
Sorry to hear you are having trouble with starting your blog.
We have added this problem to our troubleshooting section here. Please let us know if this was helpful.
The issue is tracked in the Ghost-CLI repository here.
ok , i’ am try again.
