Ghost start throws error
ghost start returns the following error:
running sudo command: systemctl is-active ghost_localhost
A ProcessError occurred.
Message: Command failed: /bin/sh -c sudo -S -p ‘#node-sudo-passwd#’ systemctl is-active ghost_localhost
unknown
Exit code: 3
and
I get this error
Failed to issue method call: Unit ghost_localhost.service failed to load: No such file or directory. See system logs and 'systemctl status ghost_localhost.service' for details.
on calling
sudo systemctl start ghost_localhost
does anybody knows how to resolve this?
Thanks in advance.
Please read through https://docs.ghost.org/docs/troubleshooting#section-message-command-failed-bin-sh-c-sudo-s-p-node-sudo-passwd-systemctl-is-active-failed-exit-code-3. If it doesn’t help, let us know here. Thanks!
Hey @Kate
I tried this but I get this error
sudo systemctl status ghost_localhost
Loaded: error (Reason: No such file or directory)
Active: inactive (dead)
still gives
Failed to issue method call: Unit ghost_localhost.service failed to load: No such file or directory. See system logs and ‘systemctl status ghost_localhost.service’ for details.
What is the output of ls -la system/files?
You can try running systemctl daemon-reload, maybe the symlinks are broken.
