Need urgent help. We need to check and remove a particular link interlinked on all our resource pages. How do we do this automatically?
Example: I want to check if this link (www.xyz.com) has been interlinked in any of our resource pages, if it is present, I want to remove all of them. How do I achieve this.
There are many ways you could find and replace a URL across the site in such a way as to change www.xyz.com to www.abc.com as a bulk job, but in this case you said you want to remove them, which implies to me that each occurrence will need some editorial decision making on how the hole will be plugged—and that’s why I’d do this as a manual job
