I need to remove several links in my posts. I have a lot of them.
How can I found these links and remove them all?
I tried the export content, but the import doesn’t work after…
Is there any other way?
Thank you.
Thank you.
The only thing that comes to my mind is to open every post you want to update in a different tab, and then use the link finder to look for those links and replace them.
In Firefox for example, you can open it by typing '.
If you think its too much, you can wait a couple days until i create a tutorial in my site [mod: dead link] [GhostPortal](https://ghostportal.co)
