Ive turn on comments . running version 5 and theme casper. But there is no comment section on my posts
Self hosting or Ghost Pro?
What’s your specific Ghost version and how long ago did you install Casper? Comments went in around 5.30, in Aug 2022, so I’m wondering if your Ghost version or theme is older than that…
yes im on version 5.53.4 and I’m self hosted on AWS lightsail
Right, but when did you install the Casper theme? I’m wondering if it has the comments code block. Check your post.hbs file for a {{comments }} helper?
thank you I manually updated the post.hbs file. that did the trick
