I’m trying to upgrade my blog from Ghost 3.12.1 to 3.15.2 but i get the following issue:
Hey @rolando & @Stromfeldt!
We’ve just released 3.15.3 which fixes the regression in minimum supported Node versions, so you should be able to update now.
We’re planning on properly bumping the minimum Node versions to 10.19.0 and 12.15.0 in the next minor release, in order to match the latest Node security releases, so I’d recommend updating your local version anyway. 12.16.3 is the newest recommended version
I was able to do it.
Thank you very much!
