Npm WARN deprecated cross-spawn-async@2.2.5
Hi :)
I already have a post, but it’s closed. so that’s why I make this post.
I want to fix the npm WARN deprecated
Version
ghost-mgr@server:/var/www/ghost$ ghost --version
Ghost-CLI version: 1.9.9
Ghost version: 2.12.0 (at /var/www/ghost)
Warning
ghost-mgr@server:/var/www/ghost$ sudo npm i -g ghost-cli@latest
npm WARN deprecated cross-spawn-async@2.2.5: cross-spawn no longer requires a build toolchain, use it instead
/usr/local/bin/ghost -> /usr/local/lib/node_modules/ghost-cli/bin/ghost
/usr/local/lib
└── ghost-cli@1.9.9
How to fix this warning: npm WARN deprecated cross-spawn-async@2.2.5: cross-spawn no longer requires a build toolchain, use it instead
I know its not a problem for the site to run, but I tired of the warning
My homepage is: https://www.halfdaner.dk and its running fine - and it hosted by digitalocean, but im tired of the warning
Kind regards
Thomas
It’s a warning from npm. If you want to fix it then you’d need to send a PR to Ghost-CLI GitHub - TryGhost/Ghost-CLI: CLI Tool for installing & updating Ghost upgrading whichever dependency is triggering the warning.
Sorry Hannah, I’m a noob. What did you mean with PR
Can you help me out here?
PR = GitHub Pull Request
https://help.github.com/articles/about-pull-requests/
Hi again :)
Thanks for your reply!
I’m really a NOOB! Really!! - So please step by step.
Can someone guide me step by step to find the dependency that is triggering the warning?
and make a pull request?
I have tried to reinstall the hole server from digital ocean, and still, the same error when I running “sudo npm i -g ghost-cli@latest” efter end install
Thanks @dsecareanu
Thanks for explaining this to me. :blush:
Any Help Will Be Appreciated
It’s not an error, it’s just a warning and is completely safe to ignore (you’ll probably see a lot of them over time :wink:) . It won’t go away from re-installing anything, the dependencies/code in GitHub - TryGhost/Ghost-CLI: CLI Tool for installing & updating Ghost need updating and a new Ghost-CLI version released, once a new release has been made public you would need to install the new version of Ghost-CLI for the warning to disappear.
If you’re up for going down a rather large node.js development rabbit hole here are some resources that may be useful if you want to help update the Ghost-CLI dependencies (in addition to the pull requests link above):
Yarn (we use this as an alternative client to the npm registry)
If you only want to run your site, ignore the warning and be happy :slight_smile:
Hi :slight_smile:
Thanks for explaining me this in languages, so I understand it. :wink:
I will ignore the warning, and wait for an update
Kind regards
Thomas
