After I updated Ghost / NPM with this command: “sudo npm i -g ghost-cli@latest”
I get this warning:
ghost-mgr@server:/var/www/ghost$ sudo npm i -g ghost-cli@latest
npm WARN deprecated mkdirp@0.5.4: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
/usr/bin/ghost -> /usr/lib/node_modules/ghost-cli/bin/ghost
+ ghost-cli@1.13.1
updated 1 package in 14.002s
How to fix this warning??
BTW: If I run: “ghost update” no errors
I have also found a new file in my dir (/var/www/ghost/) -> called: “package-lock.json”
It has this content
"requires": true,
"lockfileVersion": 1,
"dependencies": {
"mkdirp": {
"version": "1.0.3",
"resolved": "https://registry.npmjs.org/mkdirp/-/mkdirp-1.0.3.tgz",
"integrity": "sha512-6uCP4Qc0sWsgMLy1EOqqS/3rjDHOEnsStVr/4vtAIK2Y5i2kA7lFFejYrpIyiN9w0pYf4ckeCYT9f1r1P9KX5g=="
What did this file do? Shut i keep it, or can i delete it?
I hope you can help me out here.
Kind regards
Thomas
