I’ve had my ghost blog running for some time, rolling through a number of upgrades and one reinstallation over the past years.
Version: 3.0.2
Default configuration - no code changes from base.
Browser isn’t relevant for my problem.
No errors.
I’m installed on Linux Mint and my issue is as follows:
The cache folder in my home directory contains a folder for Yarn. Directory structure looks like this (only showing one module “acorn” as example - there are thousands of others in the v4 folder):
/yarn
/v4
/npm-acorn-3.3.0-xxx
/npm-acorn-5.7.3-xxx
/npm-acorn-6.0.5-xxx
/npm-acorn-6.1.0-xxx
/npm-acorn-6.1.1-xxx
/npm-acorn-6.2.1-xxx
/npm-acorn-6.3.0-xxx
/npm-acorn-7.0.0-xxx
/npm-acorn-7.1.0-xxx
/v6
The server it runs on is reporting this folder as one of the largest, clocking in at over 2.6GB. This is a rolling cache that never clears automatically.
Ghost is the only application I have which uses NPM.
Housekeeping for this is super easy - head over to Installation | Yarn and follow instructions to install Yarn, then run
yarn cache clean
OR, as I discovered after combing documentation
ghost buster
In a production environment dedicated to Ghost, this is something which I think could perhaps get called after a ghost update is installed, in much the same way as old versions of Ghost itself get automatically cleaned up.
Thoughts?
Kind Regards, Pete
