I have a client still running Ghost 4.4. Yes, really. Yes, I’ve told them they should really upgrade, at least to the latest version of 4.x. But I get it… it’s easy to get stuck by dependency hell, and they’d have to upgrade node, too…
Anyway, that brings me to my problem. I wrote a bunch of code that uses the #match helper, which runs great on the later 4.x version I’m running on my dev box. I went to load it on their site, and no. No #match until 4.20. So, two questions:
Is there a list somewhere of which helper was introduced when? I’ve now run into two separate spots where a helper that was available in later 4.x wasn’t yet available in 4.4. (And no custom fields yet, either!)
Do any of you old hands have a hint for how to match a slug to a string, without #match? I’m on a tags page, trying to check if the tag is a specific value, so I’d like to
{{#match tag.slug "=" "french-podcast"}}… but no.
Thanks!
