OpenAI seems like the best org to harness the power of Ghost themes. I was analyzing their website and was wondering what API/Feature/Code I should use to create a similar effect.
Note: I know how to make and develop a ghost theme. I am purely asking on the CMS side on ghost. That means, what would be the best way to achieve the following by maximizing the usage of built-in features in ghost.
- Interactive graph and timelines
By default, ghost’s pages are similar to how ‘posts’ work. I am given an editor to write some story, but not so much else. However on this “page,” you can see that they created an interactive graph and timeline. I know that this can be done by embedding JS graphing libraries and timelines. I am questioning the CMS side on Ghost. Do you think OpenAI just made an HTML block for the graph & timeline? (i.e., if OpenAI needs to add a similar page like this, would they be able to create it by only using ghost’s admin, or would they need to open up code editor to modify their theme?)
- Call-to-action buttons under the title
Under the title & desc, there are three buttons available. If I want to mimic this, where should these links & button title should go? (i.e. where would be the best place to enter this metadata on ghost?)
- Interactive blocks
Clicking the button switches the data (you can think of the All-Missed slider on the iPhone call app.) Is the only way to replicate this is to create an HTML block?
- Footnotes
I know markdown supports footnotes, but they are extremely painful to use since I have to manually create a markdown block and type the footnote every time I want to create them. Is there any easier way to make a footnote? Hope it works natively [[something like this]] to automatically create footnotes, just like automatically creates codeblocks.
