Dear All,
I am relatively new to Ghost.
I am setting up a site with a single staff member, but would like to display a page with a list of people that are in my group (each with a picture and a few words next to them).
I am on Ghost starter plan, hence I can not run my own custom theme. Is it possible to create a page which automatically lists a group of, say, contributors to the site? Can I do this without creating a custom theme? Can I decide in which order they are displayed?
Thank you.
Daniele
I’d create this as a page. You might need to do some layout in an html card, but this should be doable! :)
Another option would be to use a product card or an image and caption, and rearrange the layout using css code injection to get the side by side look you want.
Thanks, could you elaborate on this? I am no an experienced designer
Very basic example in an html card (put in the body of the post in an HTML card):
<div class="side-by-side">
<img class="img-side-by-side" src="https://yoururltotheimage">
<div class="text-side-by-side">
Put your text here, using <p> if you have paragraph breaks.
</div>
</div>
In code injection or in the HTML card:
<style>
.side-by-side {
display: flex;
flex-direction: row;
.image-side-by-side {
max-width: 50%;
</style>
That’s very basic, and styling could definitely be improved, but it gives a layout like this, which I think is what you described?:
Thank you so much, this is awesome!
Hi @Cathy_Sarisky your idea is what I needed. There should be a closing </style> in the second code snippet, just in case someone else tries to copy/paste your code. Thanks again!
absolutely right. I’ll fix the post! :)
