Pages (but not Posts or static homepage) are blank
While setting up my static homepage and routing, I did something causing my pages (but not posts) to appear blank. Posts work fine. My homepage, built on a version of the page template, works fine.
Pages themselves are blank.
Example page: The Founder's Guide to Hiring
pages.hbs
{{!< default}}
{{> header}}
<main class="wrapper_digitus" role="main">
{{#page}}
<article class="article_digitus" role="article" itemscope itemtype="http://schema.org/Article">
	<header class="postheader_digitus">
        <h1 class="posttitle_digitus" itemprop="headline">{{title}}</h1>
        <hr class="pause">
	</header>
	<div class="postcontent_digitus" itemprop="articleBody">
		{{content}}
	</div>
</article>
{{/page}}
</main>
{{> footer}}
routes.yaml
routes:
data: page.home
template: home
collections:
/articles/:
permalink: /{slug}/
template: index
taxonomies:
tag: /tag/{slug}/
author: /author/{slug}/
I already recreated the page.hbs file from what was working on the static homepage and post.hbs.
Can anyone provide any guidance on where I might look to troubleshoot next?
Thanks,
Fred
For legacy reasons, normal pages in Ghost have all their data associated with a data key post and so they use {{#post}}{{/post}} where the newer dynamic route pages uses {{#page}}{{/page}} by default.
Or another way of putting it is that:
data: page.home is shorthand for
   data:
     page: page.home
So, home.hbs should use {{#page}}{{/page}}
And page.hbs should use {{#post}}{{/post}}
Alternatively, if you change your routes to this:
routes:
    data:
      post: page.home
      template: home
You can change the home page data key to post and then consistently use {{#post}}{{/post}} everywhere.
FWIW yes this is daft and confusing and we need to fix it.
That is confusing. Now I don’t feel so bad that I couldn’t figure it out myself.
Thanks, Hannah. Your explanation was super helpful. I’ve got it working with the your first suggestion.
