I’m using the Pinterest “Pin It” script in the Code Injection.
<script src="//assets.pinterest.com/js/pinit.js"
type="text/javascript" async defer
data-pin-hover="true"></script>
It works properly but I’m having an unexpected issue:
the button, visible on hover, scrolls over my sticker header as opposed to beneath it.
Any help is greatly appreciated.
P.S. I am not a developer/coder so I’m trying to figure this out as a total novice.
I’m not a developer/coder either, but had a similar problem with some injected code appearing above something it shouldn’t … the solution was to change the z-index in the CSS.
Cheers
I’ve tried messing with the z-index dozens of times in the last several hours and nothing.
I said I wasn’t a developer or coder … why not ask @Cathy_Sarisky 's intern ?
Raki
August 29, 2024, 9:52pm
5
If you could provide a link and describe the effects you want, it would be easier to help you.
Sorry about that. Site is not yet live (haven’t launched yet). Is there a way I can contact you privately?
