Portal btn not showing on mobile
I’ve been using a modified Dawn theme, and recently updated to be aligned with the main theme; though I realize too late that the portal button no longer appears in the mobile display of the theme.
Can someone direct me to where in the code I should look to get the portal button to display on mobile versions of the Dawn theme?
Thank you.
It appears for the Choi theme … I’ve searched the code for the Dawn theme and the shared-theme-assets … ergo, I’m asking here for any insight. Again, thank you.
Sounds like the same thing as this:
From the commit:
  • These days, themes have subscribe and account buttons built in. The Portal Button should be opt-in rather than opt-out.
  • On mobile devices, the Portal Button takes up too much valuable real estate.
Thank you!! I thought that could be … though some themes still have it available – I’ll look into how to reverse it … as someone else said … “valuable real estate” is entirely an opinion … I loved having that button there!
Just noticed this as well. We’re on a modified Tripoli theme.
Thanks for the post, which reminded me that I’ve been meaning to write this up!
OMG, this is amazing !! Thank you!!!
