When I edit a title to remove capitalization, Ghost is adding a 2 on the Post URL
Hi @rijo , on the right side panel you can set any url manually. It adds “2” most possibly because it see that it’s already taken.
I would recommend to simly go an override it here:
Or try to save as is, then re-open for edititng and try again to override.
Thanks for the help
Yeah I’m doing that. But it’s just annoying.
If you change a letter from F to f, it immediatly adds a 2 in the URL…
