Thanks for your help. The Ghost v2 instance has just one error in the logs. At the bottom is the error message that appears in the browser console.
"name": "Log",
"hostname": "sirius.uberspace.de",
"pid": 4704,
"level": 50,
"req": {
"meta": {
"requestId": "0212a6a0-ac62-11e9-b6b8-4b1926406d90",
"userId": null
"url": "/users/me/?include=roles",
"method": "GET",
"originalUrl": "/ghost/api/v2/admin/users/me/?include=roles",
"params": {},
"headers": {
"host": "localhost:62448",
"user-agent": "Mozilla/5.0 (X11; Linux x86_64; rv:68.0) Gecko/20100101 Firefox/68.0",
"accept": "application/json, text/javascript, */*; q=0.01",
"accept-language": "en-US,en;q=0.5",
"accept-encoding": "gzip, deflate",
"referer": "http://blog2.kloetzl.info/ghost/",
"content-type": "application/json; charset=UTF-8",
"x-ghost-version": "2.25",
"app-pragma": "no-cache",
"x-requested-with": "XMLHttpRequest",
"dnt": "1",
"x-forwarded-proto": "http",
"x-forwarded-port": "80",
"x-forwarded-for": "141.5.9.188, 141.5.9.188",
"x-forwarded-host": "blog2.kloetzl.info",
"x-forwarded-server": "kloetzl.sirius.uberspace.de",
"connection": "Keep-Alive"
"query": {
"include": "roles"
"res": {
"_headers": {
"x-powered-by": "Express",
"cache-control": "no-cache, private, no-store, must-revalidate, max-stale=0, post-check=0, pre-check=0",
"content-type": "application/json; charset=utf-8",
"content-length": "321",
"etag": "W/\"141-X35vf/6EyNzbfO01HVqKgP8R7ps\"",
"vary": "Accept-Encoding"
"statusCode": 403,
"responseTime": "11ms"
"err": {
"id": "0213df20-ac62-11e9-b6b8-4b1926406d90",
"domain": "http://blog2.kloetzl.info/",
"code": null,
"name": "NoPermissionError",
"statusCode": 403,
"level": "normal",
"message": "Authorization failed",
"context": "\"Unable to determine the authenticated user or integration. Check that cookies are being passed through if using session authentication.\"",
"stack": "NoPermissionError: Authorization failed\n at new NoPermissionError (/home/kloetzl/ghost2/node_modules/ghost-ignition/lib/errors/index.js:114:23)\n at authorizeAdminApi (/home/kloetzl/ghost2/core/server/services/auth/authorize.js:76:25)\n at Layer.handle [as handle_request] (/home/kloetzl/ghost2/node_modules/express/lib/router/layer.js:95:5)\n at next (/home/kloetzl/ghost2/node_modules/express/lib/router/route.js:137:13)\n at authenticate (/home/kloetzl/ghost2/core/server/services/auth/session/middleware.js:103:16)\n at Layer.handle [as handle_request] (/home/kloetzl/ghost2/node_modules/express/lib/router/layer.js:95:5)\n at next (/home/kloetzl/ghost2/node_modules/express/lib/router/route.js:137:13)\n at authenticate (/home/kloetzl/ghost2/core/server/services/auth/api-key/admin.js:42:16)\n at Layer.handle [as handle_request] (/home/kloetzl/ghost2/node_modules/express/lib/router/layer.js:95:5)\n at next (/home/kloetzl/ghost2/node_modules/express/lib/router/route.js:137:13)\n at Route.dispatch (/home/kloetzl/ghost2/node_modules/express/lib/router/route.js:112:3)\n at Layer.handle [as handle_request] (/home/kloetzl/ghost2/node_modules/express/lib/router/layer.js:95:5)\n at /home/kloetzl/ghost2/node_modules/express/lib/router/index.js:281:22\n at param (/home/kloetzl/ghost2/node_modules/express/lib/router/index.js:354:14)\n at param (/home/kloetzl/ghost2/node_modules/express/lib/router/index.js:365:14)\n at Function.process_params (/home/kloetzl/ghost2/node_modules/express/lib/router/index.js:410:3)\n at next (/home/kloetzl/ghost2/node_modules/express/lib/router/index.js:275:10)\n at Function.handle (/home/kloetzl/ghost2/node_modules/express/lib/router/index.js:174:3)\n at router (/home/kloetzl/ghost2/node_modules/express/lib/router/index.js:47:12)\n at Layer.handle [as handle_request] (/home/kloetzl/ghost2/node_modules/express/lib/router/layer.js:95:5)\n at trim_prefix (/home/kloetzl/ghost2/node_modules/express/lib/router/index.js:317:13)\n at /home/kloetzl/ghost2/node_modules/express/lib/router/index.js:284:7"
"msg": "Authorization failed",
"time": "2019-07-22T09:20:55.323Z",
"v": 0
Browser error:
Error while processing route: posts JSON.parse: unterminated string literal at line 1 column 265 of the JSON data deserialize@http://blog2.kloetzl.info/ghost/assets/ghost.min-42b2778d11b38793c166227bdf1b2d83.js:1896:13
applyTransforms/<@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:8443:8
eachTransformedAttribute/<@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:7911:245
eachTransformedAttribute@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:7911:227
applyTransforms@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:8442:10
normalize@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:8456:265
normalize@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:8368:55
n@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:2561:9
_normalizePolymorphicRecord@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:8495:68
_normalizeArray/<@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:8492:67
_normalizeArray@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:8492:27
_normalizeResponse@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:8501:66
normalizeArrayResponse@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:8452:1180
normalizeArrayResponse@http://blog2.kloetzl.info/ghost/assets/ghost.min-42b2778d11b38793c166227bdf1b2d83.js:1398:105
normalizeQueryResponse@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:8452:661
normalizeResponse@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:8449:25
ge@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:7932:65
_query/</<@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:8133:326
f@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:4598:17
_@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:4608:12
W@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:4606:128
M</t.invoke@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:4137:163
M</t.flush@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:4129:74
z</t.flush@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:4142:358
F</n._end@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:4204:9
F</n.end@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:4159:230
F</n._run@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:4206:118
F</n._join@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:4205:246
F</n.join@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:4170:13
d@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:3023:28
_makeRequest/c</<@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:7174:11
p@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:558:118
fireWith@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:559:694
W@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:839:443
n/<@http://blog2.kloetzl.info/ghost/assets/vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:849:206
2 vendor.min-f46d38749a8eedcd575bf79c4d1ba4e4.js:2225:108
