Response code 405 (Method Not Allowed)
Hi, there seems to be a broken process when publishing a new post related to the XMLRPC service. Every time I publish a new post (this is on a self hosted instance of Ghost), I see the following error in my logs. I have to publish the post a second time for it to actually work, otherwise I get 500 errors when trying to visit the post in my browser.
2018-07-10T15:15:17.328794+00:00 app[web.1]: INFO [2018-07-10 15:15:17] "PUT /build/ghost/api/v0.1/posts/5b44cd6c50d56b0015b4e720/?include=authors,tags,authors.roles" 200 129ms
2018-07-10T15:15:17.355616+00:00 app[web.1]: [2018-07-10 15:15:17] ERROR
2018-07-10T15:15:17.355620+00:00 app[web.1]:
2018-07-10T15:15:17.355622+00:00 app[web.1]: NAME: InternalServerError
2018-07-10T15:15:17.355624+00:00 app[web.1]: MESSAGE: Response code 405 (Method Not Allowed)
2018-07-10T15:15:17.355626+00:00 app[web.1]:
2018-07-10T15:15:17.355628+00:00 app[web.1]: level:normal
2018-07-10T15:15:17.355629+00:00 app[web.1]:
2018-07-10T15:15:17.355631+00:00 app[web.1]: The xmlrpc service was unable to send a ping request, your blog will continue to function.
2018-07-10T15:15:17.355634+00:00 app[web.1]: If you get this error repeatedly, please seek help on http://docs.ghost.org.
2018-07-10T15:15:17.355636+00:00 app[web.1]: InternalServerError: Response code 405 (Method Not Allowed)
2018-07-10T15:15:17.355638+00:00 app[web.1]: at new GhostError (/app/node_modules/ghost/core/server/lib/common/errors.js:9:26)
2018-07-10T15:15:17.355639+00:00 app[web.1]: at /app/node_modules/ghost/core/server/services/xmlrpc.js:75:38
2018-07-10T15:15:17.355641+00:00 app[web.1]: at tryCatcher (/app/node_modules/bluebird/js/release/util.js:16:23)
2018-07-10T15:15:17.355643+00:00 app[web.1]: at Promise._settlePromiseFromHandler (/app/node_modules/bluebird/js/release/promise.js:512:31)
2018-07-10T15:15:17.355645+00:00 app[web.1]: at Promise._settlePromise (/app/node_modules/bluebird/js/release/promise.js:569:18)
2018-07-10T15:15:17.355646+00:00 app[web.1]: at Promise._settlePromise0 (/app/node_modules/bluebird/js/release/promise.js:614:10)
2018-07-10T15:15:17.355648+00:00 app[web.1]: at Promise._settlePromises (/app/node_modules/bluebird/js/release/promise.js:689:18)
2018-07-10T15:15:17.355650+00:00 app[web.1]: at Async._drainQueue (/app/node_modules/bluebird/js/release/async.js:133:16)
2018-07-10T15:15:17.355651+00:00 app[web.1]: at Async._drainQueues (/app/node_modules/bluebird/js/release/async.js:143:10)
2018-07-10T15:15:17.355653+00:00 app[web.1]: at Immediate.Async.drainQueues (/app/node_modules/bluebird/js/release/async.js:17:14)
2018-07-10T15:15:17.355655+00:00 app[web.1]: at runCallback (timers.js:810:20)
2018-07-10T15:15:17.355657+00:00 app[web.1]: at tryOnImmediate (timers.js:768:5)
2018-07-10T15:15:17.355658+00:00 app[web.1]: at processImmediate [as _immediateCallback] (timers.js:745:5)
2018-07-10T15:15:17.355660+00:00 app[web.1]:
2018-07-10T15:15:17.355661+00:00 app[web.1]: HTTPError: Response code 405 (Method Not Allowed)
2018-07-10T15:15:17.355663+00:00 app[web.1]: at stream.catch.then.data (/app/node_modules/got/index.js:182:13)
2018-07-10T15:15:17.355665+00:00 app[web.1]: at tryCatcher (/app/node_modules/bluebird/js/release/util.js:16:23)
2018-07-10T15:15:17.355667+00:00 app[web.1]: at Promise._settlePromiseFromHandler (/app/node_modules/bluebird/js/release/promise.js:512:31)
2018-07-10T15:15:17.355668+00:00 app[web.1]: at Promise._settlePromise (/app/node_modules/bluebird/js/release/promise.js:569:18)
2018-07-10T15:15:17.355670+00:00 app[web.1]: at Promise._settlePromise0 (/app/node_modules/bluebird/js/release/promise.js:614:10)
2018-07-10T15:15:17.355672+00:00 app[web.1]: at Promise._settlePromises (/app/node_modules/bluebird/js/release/promise.js:693:18)
2018-07-10T15:15:17.355673+00:00 app[web.1]: at Async._drainQueue (/app/node_modules/bluebird/js/release/async.js:133:16)
2018-07-10T15:15:17.355675+00:00 app[web.1]: at Async._drainQueues (/app/node_modules/bluebird/js/release/async.js:143:10)
2018-07-10T15:15:17.355677+00:00 app[web.1]: at Immediate.Async.drainQueues (/app/node_modules/bluebird/js/release/async.js:17:14)
2018-07-10T15:15:17.355678+00:00 app[web.1]: at runCallback (timers.js:810:20)
2018-07-10T15:15:17.355680+00:00 app[web.1]: at tryOnImmediate (timers.js:768:5)
2018-07-10T15:15:17.355681+00:00 app[web.1]: at processImmediate [as _immediateCallback] (timers.js:745:5)
Yep
That sounds completely unrelated to the xmlrpc ping error (that is just a background process and has no bearing on the save/publication). Do you have the logs from the 500 errors you’re seeing?
So here are the series of events that cause the 500.
When I try to create a new story/post in Ghost (self hosted on Heroku using the GitHub - cobyism/ghost-on-heroku: One-button Heroku deploy for the Ghost blogging platform. project), I get the xmlrpc error, and then when I try to visit the newly created post, I then get the 500.
However, if I publish the post a second time, it seems to then work fine.
Logs:
This is caused by the broken xmlrpc ping domain tracked here:
There is already a PR for it, will be released soon.
You can ignore the error log for now, it does not affect post creation or editing, it’s just a log telling that something isn’t working.
Any idea why I need to “publish” my posts twice for them to show up? On initial publish, I get the xmlrpc error, and trying to visit the post results in a 500 (Resource Not Found)… when I hit publish a second time, it seems to work. Hmmmm. related?
I am not sure what you mean exactly :thinking:
If the post goes live (from draft to publish), an event will be triggered and this triggers the xmlrpc ping. If the post is already live and you just save/update the post, no publish event is triggered, because the post is already published.
Basically this is what happens:
  • Create new post/story by hitting Publish
  • Try to visit the newly published post and get a 500 error (Resource not found)
  • Hit Publish again on the same post
  • Try to visit the newly published post and it loads just fine
When looking through the logs, I see 2 errors, which I’ve linked to in this gist:
I am not sure if its related to the xmlrpc ping or not. Could be unrelated, but whatever is happening, it requires me to publish my posts twice for them to work
No this doesn’t sound related. Which Ghost version are you on?
You are getting a 500 when visiting the post on your blog, correct? Can you please share a screenshot from this error? Furthermore, i wonder why you only see the xmlrpc error in your log. Could you please double check that there is no other error? Thanks :slight_smile:
The weirdest thing happens, Kate. About 50% of the time, the post loads and the other 50% returns a 500. I’ve recorded a video of it here:
https://cl.ly/sve7
I’ve also noticed that this newly created post doesn’t always show up on the homepage. If I keep refreshing, sometimes it shows up, other times it doesn’t. Interestingly, if I restart the server, everything seems to work fine. Its almost like all of the Ghost instances are not in sync (I am running this on Heroku with 2 dynos, so the node app is being forked into 2 processes.) Do I need to do something special to make the Ghost app work with a forked process?
Thanks for coming back.
From https://docs.ghost.org/docs/install
Ghost does not support clustering or multi-server setups of any description, there should only be one Ghost instance per blog. The recommended scaling and performance approach is to put a cache and/or CDN in front of your blog; pages generated by Ghost are essentially static so there should be very little traffic hitting your Ghost server with a well configured cache.
Ahh, good to know. thanks! I just scaled down to one process and things seem to be working better now.
