I just joined a team that runs a few sites using Ghost. I am confused on how to configure as existing Ghost project to run locally. I understand and have read the documentation for starting a new project and running locally, but in this case, I pulled an existing project from Github that has a file structure of ghost/content, ghost/system/files, and ghost/versions/2.0.3. I’m a bit of a Ghost noob so sorry if this is a bad question but running ‘ghost start’ in the ghost directory returns “Working directory is not a recognizable Ghost installation.
Run ghost start again within a folder where Ghost was installed with Ghost-CLI.”
Running ‘ghost install’ in the ghost directory returns ‘Message: Current directory is not empty, Ghost cannot be installed here.’ I’m missing a connection on how ghost functions. Thanks for any help!
- What’s your URL? This is the easiest way for others to debug your issue
- What version of Ghost are you using?
2.0.3 - What configuration?
- What browser?
Runghost startagain within a folder where Ghost was installed with Ghost-CLI.”
