Publication Cover
Hello, my artwork keeps getting zoomed in on the homepage but looks fine when editing in the design pane. I was hoping to have the full artwork as the cover. Is there a way to fix this? I have tried cropping and adjusting my pixel width and height but no effect.
This is going to depend on the theme you’re using. If you want to link your site, there might be an easy fix.
thank you
So that’s the source theme. The image fills a phone or big screen. It’s possible to force the image to always have the same aspect ratio (no cropping), but that means white space on the side on desktop, and above and below it on mobile
Ah.. I see it now when I change my window to a smaller size. I was just hoping it would auto fit that image.
