Publish embedded Youtube in post using Zapier
Hello,
I was able to publish content in Ghost connecting Zapier + Gmail.
It works ok with plain text, but what I wanted to do is to publish a YouTube video (embed).
What Zapier does is to write the URL of the video, not embedding the video. I tried many things but none of them worked for me.
Have you ever tried this with success?
Thanks
So do you want to publish a post in Ghost from a Gmail mail?
Hello, to be more precise what I want is:
  1. Share a YouTube video sending the link to my Gmail
  2. Connect Zapier to Gmail in order to get the video URL from the email.
  3. Connect Zapier to Ghost to publish a post with the video.
Thanks
I kind of get it but there are a couple things (sorry if im asking too much):
  1. Why do you want to add a video to a post already done from Gmail?
  2. Is your intention always post from Gmail?
  3. Are you trying to use Gmail + Ghost similar to when you save articles in Pocket? You get ideas and then you “save them” by sending a mail.
In my opinion, the best workaround is to make a post in gmail using markdown with something like Markdown here. Put the video using Markdown and then try it again.
@Joan_Moreno when configuring the Ghost integration’s “publish post” step, if you change the format to “html” you can embed Youtube videos with something like this:
<!--kg-card-begin: html-->
<iframe width="560" height="315" src="https://www.youtube.com/embed/{video id}" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<!--kg-card-end: html-->
You’ll likely need an extra “Formatter” step before the Ghost step so that you can extract the video id from the url.
No worries.
Imagine that you are away from your computer and you want to post a video that you saw in your mobile.
By sharing the video to your Gmail, Zapier makes the post in Ghost.
Thanks!
Hi @Kevin , I think you are right.
I will try, thanks!
Makes sense. I do it all the time as well, but i use the native apps which is easier!
I was asking to see if i could go beyond. If you have an android phone, you can install the app and just place it in a draft. That’s what i do (i like simple things).
Anyways, if you feel more comfortable with Gmail, @Kevin’s suggestion is on point.
That’s it! It works.
Thanks @Kevin
Thanks so much for this!!! Now to see if it works with vimeo links!
UPDATE: Works great with vimeo links without the formatter.
<iframe src="https://player.vimeo.com/video/{VIMEO VIDEO ID}" width="640" height="564" frameborder="0" allow="autoplay; fullscreen" allowfullscreen></iframe>
