Push notifications on a hosted site
Hi, I’m using the hosted version of Ghost and I’m looking to install push notifications on my blog. I’ve used onesignal previously on WordPress, but that has a native plugin on there, and when I’ve tried to install it on Ghost I’ve needed to upload files to the root folder which I don’t have access to.
Could anyone recommend any way that either this could be done with onesignal or an alternative that would work with hosted Ghost sites?
Thank you
Hello,
if you’re experienced in JS coding, I’ve built an application MVP you can use as a template or for ideas.
It uses Serverside Events & MongoDB to send out push notifications to connected clients.
Hi @tq-bit, I opened a ticket on your GitHub.
https://github.com/tq-bit/ghost-notifier/issues/1
