Remove old unused images
Problem:
As I write articles on my own instance of ghost, sometimes I drag and drop multiple instances of the same image because the size doesn’t work for the page. At times I would drop in a screenshot from a desktop or a tablet and it would fill the whole page in a post. What I would do then is resize the picture on the desktop and re-upload the same image again just smaller or bigger, so the old picture wouldn’t get to be used and just stay there in the contents folder for nothing.
Solution idea:
I suppose an image-is-used-in-the-post would be cool to add in. Then you’d only keep the images in the contents/ folder that are actually used in an article. So say when you save the post it would remember that you added an image but it’s not in the article so just delete it. Why would you keep old pictures that are not used?
An even better idea would be to add some kind of an image gallery to see what kind of content you have already with a flag showing if it’s used in a post and give the admin an option to remove it from the gallery. We’d be able to save some substantial amount of space on backups.
Sounds like this is something that could / would be implemented with Better image/file management & optimisation - #7 by chrisalley :smile:
It does sounds like it, doesn’t it :slightly_smiling_face:? Well then an up vote from me
Yep, I think I have 4 or 5 of each image testing ratios and qualities to see what turns out best in the blog vs FB card vs Twitter, especially if there is text on the image— need to make sure it shows up cleanly and is framed properly in the cards on social media. So, I feel your pain!
Sound like a tool for image scan and report unused image list then we can decision to delete or keep that files.
I also noticed that many images are stored in the history. I would be nice to clean old versions (before published) together with the images to free up space a little bit.
