Hey, If I want completely remove signup code line from every page should I remove whole:
login_panel.hbs file?
As of Ghost 4.4.0, you can now disable signups from the web UI without needing to make changes to your source. Go to Settings → Access, and you can set Subscription Access to “None”.
