So apparently the accent colour has been removed from links in the editor’s dark mode (but not light mode) in the new editor “due to issues with some site’s accent colours being unreadable in either light/dark mode”. Which is understandable. However, if your site’s accent colour didn’t actually interfere with your dark mode usage in the old editor, and you’d like it to return, and you use uBlock Origin, here’s how you can add it back in.
Open up uBlock Origin and proceed to the My Filters tab. Add in the following ten lines, then replace yoursite.ghost.io with whatever your site’s domain is. Click on Apply Changes, reload the editor (while in dark mode), and you should see the changes.
yoursite.ghost.io##.koenig-lexical > .dark .kg-prose p a span:style(color: var(--kg-accent-color) !important)
yoursite.ghost.io##.koenig-lexical > .dark .kg-prose p a em:style(color: var(--kg-accent-color) !important)
yoursite.ghost.io##.koenig-lexical > .dark .kg-prose p a strong:style(color: var(--kg-accent-color) !important)
yoursite.ghost.io##.koenig-lexical > .dark .kg-prose p a:style(text-decoration-color: var(--kg-accent-color) !important)
yoursite.ghost.io##.koenig-lexical > .dark .kg-prose blockquote > span a:style(color: var(--kg-accent-color) !important)
yoursite.ghost.io##.koenig-lexical > .dark .kg-prose blockquote > span a:style(text-decoration-color: var(--kg-accent-color) !important)
yoursite.ghost.io##.koenig-lexical > .dark .kg-prose ul a:style(color: var(--kg-accent-color) !important)
yoursite.ghost.io##.koenig-lexical > .dark .kg-prose ul a:style(text-decoration-color: var(--kg-accent-color) !important)
yoursite.ghost.io##.koenig-lexical > .dark .kg-prose h2 a:style(color: var(--kg-accent-color) !important)
yoursite.ghost.io##.koenig-lexical > .dark .kg-prose h3 a:style(color: var(--kg-accent-color) !important)
yoursite.ghost.io##.koenig-lexical .kg-prose :where(.dark a):not(:where(.not-kg-prose,[class~="not-kg-prose"] *)):style(font-weight:400 !important)
I’ve only been using this for two minutes, but that seems to have done the trick and I don’t think it’ll cause any conflicts elsewhere. If it does, or if I’ve missed something, let me know and I’ll amend it.
EDIT 23/10/23: Slight adjustment to reduce conflicts.
EDIT 24/10/23: I added in the .koenig-lexical > .dark selector so the changes only take effect on the editor’s dark mode, and I also switched the default HEX text colour to var(--kg-accent-color) as apparently it’s able to be recognised through uBlock Origin.
EDIT 8/11/23: Added in the 12th line for removal of the bolding of links (which isn’t needed in this case if you’re using your site’s brand colour).
