Robots.txt configuration
Want to modify the robots.txt, want to change currently robots.txt become:
User-agent: *
Sitemap: https://domain.com/sitemap.xml
Disallow: /ghost/
Disallow: /p/
Disallow: /member/
Disallow: /tag/
Disallow: /author/
Any body can help me?
As far as I’m aware, if you upload a robots.txt file as part of your theme, it should supersede the default Ghost robots file
is there a way to modify robots.txt on ghost pro’s $9/month plan?
Download your theme files, create a robots.txt file, save and reupload the theme.
You can’t upload themes in the basic plan.
I wish it was. Such a bummer it isn’t doable on the lowest tier :zipper_mouth_face:
Hey, Dan (and @Cowgirl too) depending on what your actual objective is there may be options to achieve them without even touching robots.txt (though I won’t know without chatting about that) - if you haven’t already, email support@ghost.org to discuss your Ghost(Pro) site.
Do you put the robots.txt files in the theme’s root directory or does it go somewhere else?
Answered my own question. Yes put robots.txt in the root directory of your theme.
I ended up adding and excluding some of the AI bots from my site. I pulled these examples from the New York Times’ robots.txt file. I figured they would have a good handle on what to exclude since they are suing OpenAI and hate the idea of training AI services on their journalism. I added the text below to the existing text in the default ghost robots.txt.
User-agent: Bytespider
Disallow: /
User-agent: CCBot
Disallow: /
User-agent: Google-Extended
Disallow: /
User-agent: GPTBot
Disallow: /
User-agent: ia_archiver
Disallow: /
User-Agent: omgili
Disallow: /
User-Agent: omgilibot
Disallow: /
