coming here from a github referece
would very much appreciate your help :)
Hi Team!
we’ve recently upgraded to 2.31 (and we love it)
our stack is using nginx (as a reverse proxy) on the server and we’re runing ghost from it’s official docker image
everything is working great except the scheduling option which yield the following logs
_Error ID:
cafae0d0-dad1-11e9-b54c-dde50bb34d18
InternalServerError: The server has encountered an error.
at new GhostError (/var/lib/ghost/versions/2.31.0/core/server/lib/common/errors.js:10:26)
at request.catch (/var/lib/ghost/versions/2.31.0/core/server/adapters/scheduling/SchedulingDefault.js:349:30)
at tryCatcher (/var/lib/ghost/versions/2.31.0/node_modules/bluebird/js/release/util.js:16:23)
at Promise._settlePromiseFromHandler (/var/lib/ghost/versions/2.31.0/node_modules/bluebird/js/release/promise.js:517:31)
at Promise._settlePromise (/var/lib/ghost/versions/2.31.0/node_modules/bluebird/js/release/promise.js:574:18)
at Promise._settlePromise0 (/var/lib/ghost/versions/2.31.0/node_modules/bluebird/js/release/promise.js:619:10)
at Promise._settlePromises (/var/lib/ghost/versions/2.31.0/node_modules/bluebird/js/release/promise.js:695:18)
at _drainQueueStep (/var/lib/ghost/versions/2.31.0/node_modules/bluebird/js/release/async.js:138:12)
at _drainQueue (/var/lib/ghost/versions/2.31.0/node_modules/bluebird/js/release/async.js:131:9)
at Async._drainQueues (/var/lib/ghost/versions/2.31.0/node_modules/bluebird/js/release/async.js:147:5)
at Immediate.Async.drainQueues [as _onImmediate] (/var/lib/ghost/versions/2.31.0/node_modules/bluebird/js/release/async.js:17:14)
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
at process.topLevelDomainCallback (domain.js:126:23)
HTTPError: Response code 301 (Moved Permanently)
at EventEmitter.emitter.on (/var/lib/ghost/versions/2.31.0/node_modules/got/source/as-pro_
the nginx logs show also this call
nginx.1 | <my site> 172.17.0.1 - - [20/Sep/2019:23:18:59 +0000] "PUT /ghost/api/v0.1/schedules/posts/5d85573bd59d65000127d103?client_id=ghost-scheduler&client_secret=<my secret> HTTP/1.1" 301 178 "-" "Ghost/2.31.0 (https://github.com/TryGhost/Ghost)"
also accessing the resource manually (with a browser) yield :
"errors": [
"message": "Resource not found",
"errorType": "NotFoundError"
To Reproduce
- install ghost with docker
docker run -d --name my-ghost \
--restart always \
-p 3002:2368 \
-e 'VIRTUAL_HOST=<my domain>' \
-e 'VIRTUAL_PORT=3002' \
-e 'NODE_ENV=production' \
-e 'url=<my url>' \
ghost:2.31.0-alpine
- configure nginx
server {
server_name <your domain>;
listen 80;
location / {
proxy_pass http://localhost:3002/;
Any other info e.g. Why do you consider this to be a bug? What did you expect to happen instead?
Technical details:
- Ghost Version: 2.31.0
- Node Version: v6.11.2
- Browser/OS: -
- Database: SQLite Database
