For some reason for something like 20% of users in any given 1-hour chunk, my self-hosted Ghost blog ends up taking 60 seconds to serve. In the Chrome devtools, this time shows up under the “Initial Connection” header, in the subcategory “Stalled”.
- What’s your URL? This is the easiest way for others to help you
URL: Mindingourway.com
- What version of Ghost are you using? If it’s not the latest, please update Ghost first before opening your topic
Latest version (4.46.0)
- How was Ghost installed and configured?
Self-hosted aws instance using the ghost-cli
- What Node version, database, OS & browser are you using?
Database: MySQL
Node version: v12.19.0
OS: MacOS (But reproduces on Linux, Windows, MacOS)
Browser: Chrome
No errors in the logs or the console
Try reaching mindingourway.com. Decent chance it takes a really long time. Problem tends to go away upon refresh, so make sure you have your devtools open when you open the site the first time.
