I set up Ghost a little ways back and then got notifications that the SSL cert was going to expire. When I first set up the site, I really don’t remember how I configured the SSL cert (whether it was manual or through Ghost) though I’d guess it was through Ghost. I read online that it auto-renews so I figured I didn’t have to worry. Today the cert expired and I’m unable to renew it. I’ve spent about 6 hours debugging and have gotten nowhere yet :/
Here is a log of things I’ve tried and related posts:
Invalid response from acme-challenge when setting up SSL
- This person’s issues were due to an odd setup
Ghost setup ssl not working
- No one helped this poor soul
Problem setting up ssl - #10 by Michel_Calheiros
- Could go at it setting up certbot manually but ideally the Ghost setup will just work
Try too many times and you get rate limited. I hit this but it resets every hour so that’s not the problem.
Updating ACME and running the script did not help.
Similarly, running things manually also didn’t work
Having ports 443 and 80 open does not seem to be related.
What’s your URL? This is the easiest way for others to debug your issue
ghost.themetric.org -
Ghost-CLI version: 1.14.1
Ghost version: 3.11.0 (at /var/www/ghost) -
What configuration?
Hosted on Vultr. Domain via GoDaddy. Using Ghost as CMS, consuming data via Gatsby. -
What browser?
N/A -
ghostuser@metric:/var/www/ghost$ ghost setup ssl
? Enter your email (For SSL Certificate) cameroncabo@gmail.com
+ sudo /etc/letsencrypt/acme.sh --issue --home /etc/letsencrypt --domain ghost.themetric.org --webroot /var/www/ghost/system/nginx-root --reloadcmd "nginx -s reload" --accountemail cameroncabo@gmail.com
✖ Setting up SSL
One or more errors occurred.
1) ProcessError
Message: Command failed: /bin/sh -c sudo -S -p '#node-sudo-passwd#' /etc/letsencrypt/acme.sh --issue --home /etc/letsencrypt --domain ghost.themetric.org --webroot /var/www/ghost/system/nginx-root --reloadcmd "nginx -s reload" --accountemail cameroncabo@gmail.com
[Wed Jun 17 00:56:40 UTC 2020] ghost.themetric.org:Verify error:Invalid response from http://ghost.themetric.org/private/?r=%2F.well-known%2Facme-challenge%2FoXpJL_l0AFAxmVU3mlZCQVHDFV1MUdRoTISo2NPkBVA [45.32.218.227]:
[Wed Jun 17 00:56:40 UTC 2020] Please add '--debug' or '--log' to check more details.
[Wed Jun 17 00:56:40 UTC 2020] See: https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.sh
[Wed Jun 17 00:56:36 UTC 2020] Single domain='ghost.themetric.org'
[Wed Jun 17 00:56:36 UTC 2020] Getting domain auth token for each domain
[Wed Jun 17 00:56:37 UTC 2020] Getting webroot for domain='ghost.themetric.org'
[Wed Jun 17 00:56:37 UTC 2020] Verifying: ghost.themetric.org
Exit code: 1
OS: Ubuntu, v18.04.4 LTS
Node Version: v10.21.0
Ghost Version: 3.11.0
Ghost-CLI Version: 1.14.1
Environment: production
Command: 'ghost setup ssl'
Additional log info available in: /home/ghostuser/.ghost/logs/ghost-cli-debug-2020-06-17T00_56_40_476Z.log
Trying to run it directly:
root@metric:/etc/letsencrypt# /etc/letsencrypt/acme.sh --force --renew --home /etc/letsencrypt --domain ghost.themetric.org --webroot /var/www/ghost/system/nginx-root --reloadcmd "nginx -s reload" --accountemail cameroncabo@gmail.com
[Wed Jun 17 01:13:47 UTC 2020] Renew: 'ghost.themetric.org'
[Wed Jun 17 01:13:48 UTC 2020] Single domain='ghost.themetric.org'
[Wed Jun 17 01:13:48 UTC 2020] Getting domain auth token for each domain
[Wed Jun 17 01:13:49 UTC 2020] Getting webroot for domain='ghost.themetric.org'
[Wed Jun 17 01:13:49 UTC 2020] Verifying: ghost.themetric.org
[Wed Jun 17 01:13:52 UTC 2020] ghost.themetric.org:Verify error:Invalid response from http://ghost.themetric.org/private/?r=%2F.well-known%2Facme-challenge%2F40AgwTHbkZginHrTh1Wnsso8wpt0iidRzYsUr59gG3Y [45.32.218.227]:
[Wed Jun 17 01:13:52 UTC 2020] Please add '--debug' or '--log' to check more details.
[Wed Jun 17 01:13:52 UTC 2020] See: https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.sh
Unsure
Please let me know if any other info would be useful!
