Hello, I tried to route my landing page to a different page, and it didn’t work, as my website says 404 error. I tried to redownload the file and make changes, but it won’t even let me upload a new file, it says “settings won’t fetch”, what do I do now?
FYI: I am a total beginner to any type of routing/coding/etc. so it will have to be really broken down to me
Welcome to Ghost!
When you say you changed your routing, do you mean you uploaded a new routes.yaml, or that you made changes to whatever proxy (nginx?) you have sitting in front of Ghost?
Uploading a weird routes.yaml shouldn’t actually stop you from getting to the admin pages. If you go directly to yoursite.tld/ghost/ , does that let you get into the server?
If you don’t mean that you uploaded a new routes.yaml, please explain in more detail what you did so that hopefully someone can help!
You don’t say anything about proxying, but just in case:
- If you try to open yoursite.tld/ghost/ with dev tools (F12) open, are there any informative console messages?
- Are there any failures in the network tab?
- If you’ve turned on something like Cloudflare or made other changes to proxying/security, it’d be worth turning them off temporarily to see if the problem goes away. It’s really easy to mess up URL rewriting with Cloudflare, and that can cause a lot of problems with the admin panel.
