I am on source v1.1.2
I want to make a page that shows all my posts — either with infinite scroll or with pagination.
In the absence of other routing, doesn’t Source already do that?
Well I thought this would be the case.
Here is my page: skillspeed.io
I thought the landing page (home) would show all my posts
That’s very odd. I can see them on the site map but not on the front page. I also tried /page/2/, but no.
Where are you hosted?
Any edits to your theme?
Can you post your routes.yaml file? It’s available to download in /ghost > settings (gear icon) labs.
Any errors in the browser console? Press f12 then the console tab to access. I’m looking for a red error, not yellow warning.
If you are self hosting, any errors in the ghost logs on the server?
I am not self-hosting. I should be hosted by ghost.
I don’t think I made any major edits to the theme.
my routes.yaml file
routes:
collections:
permalink: /{slug}/
template: index
taxonomies:
tag: /tag/{slug}/
author: /author/{slug}/
I get this error message when I access the home page skillspeed.io/:1 Unchecked runtime.lastError: The message port closed before a response was received. :
So this is a problem with the way this theme is constructed, it looks like. It’s making a {{#get}} request for posts, instead of using the posts on the route, and so it doesn’t paginate.
It’s not something you’re doing wrong, it’s just a problem with the theme.
I had this problem with source theme too, it seems there is a pagination threshold defined in the json file which is 16. Everything between 12 and 16 is in limbo on the startpage. Ghost support told me they’ll fix it.
Fascinating. So a good response is to make more posts? ;)
That’s always a good response! When in doubt, make more content! :) laughing
