How to show all blog posts in a page? I mean a single page which will display all articles/blog posts available in the ghost blog.
What’ll be the code for doing that?
Ghost Version: 3.40.5
Debian 10.7 Stable
Debian 10.7 Stable
This is possible by creating an additional template file in your theme and pointing the routes.yaml file to it.
So, let’s suppose you create the following file in your theme: all-posts.hbs
Containing something similar to this:
{{!< default}}
{{#get "posts" limit="all"}}
{{#foreach posts}}
<article class="{{post_class}}">
<header class="post-header">
<h1 class="post-title">{{title}}</h1>
<section class="post-meta">
<time class="post-date" datetime="{{date format='YYYY-MM-DD'}}">
{{date format="DD MMMM YYYY"}}
</time>
{{tags prefix=" on "}}
</section>
</header>
<section class="post-content">
{{content}}
</section>
</article>
{{/foreach}}
{{/get}}
Now in your routes.yaml set the URL:
## routes.yaml
routes:
/all-posts/: all-posts
It’s not working. I am using a custom theme, not default one called ‘Casper’.
I have created “all-posts.hbs” under that theme with your given contents and also edited ‘routes.yaml’ file. After that I restart the ghost process:
ghost restart
when I go to localhost:2368/all-posts/
it’s saying 404 Error, page not found.
Here’s my theme tree and the contents of “all-posts.hbs”
That is strange, I tested it here on a local install too and it works.
Are you sure you uploaded the routes.yaml correctly under Settings > Labs > Routes?
Can you share a screenshot of your routes.yaml? Just to check nothing funky is going on in there
Yes, I have edited my current routes.yaml with required line and it saved under /content/settings/ folder.
Here’s the contents of that file:
routes:
collections:
permalink: /{slug}/
template: index
taxonomies:
tag: /tag/{slug}/
author: /author/{slug}/
/all-posts: all-posts
Anything wrong here?
One more thing plz. I have tested this page by using custom page template and creating a new page with that template.
Text and headline alignment are not perfectly matching with the screen. Too much aligned to left of the screen. Check screenshot:
How to align those on center?
Yup, you did not follow the YAML syntax requirements. This should do the trick, edit the file, upload it and restart Ghost:
routes:
collections:
permalink: /{slug}/
template: index
taxonomies:
tag: /tag/{slug}/
That’s a whole new question.
Text alignment is configured via HTML or CSS. There are so many ways to achieve it:
<center> your text goes here </center>
text-align property of the containing element https://www.w3schools.com/cssref/pr_text_text-align.ASP
margin-left and margin-right properties of the containing elementIt solved the issue, many thanks.
